Charge Item on Blanket Sales Order
Hi Everybody
When create 1 Blanket Sales Order. On Sales Line include Item and charge (item).
But when I make order to Sales Order then Charge (Item) does not exits on Sales Line.
I have to configure how to include charge (Item) when Make Order to Sales Order.
Thanks so much.
dinhson
Which version of NAV are you using? As far as I know there was a glitch in NAV 5.0 but was fixed in later versions.
Thanks sbhatbng reply.
I useing version NAV 2013.
Hi Dinhson,
The blanket order functionality works by filtering remaining lines with a “Qty. to Ship” <> 0. And you don’t show that column, but if the field is zero on the item charge lines, then it’s not copy the lines into the sales order.
