Hello,
I have been getting problems trying to change the status of a Prod BOM using the Navision webservice (Page webservice with object id: 99000786)
For example,
I invoke the Read function in the web-service with the parameter (No = 350911-20).
The object that the Read function returns is then modified so the Status value is set to to “Certified”.
I then call the Update function with the parameter being the ProdBOM, and I get the error:
“Status must not be Certified in Production BOM Header No.=‘350911-20’.”
The status was originally Under Development.
Is there some limitations on changing the status using web services?
I can change the"Status" value of 350911-20 in Navision manually and it works fine.
