Changing reporting currency in AX 2012 R2
Is there any way to change the reporting currency assigned in the Ledger? I cannot edit it since it is grayed out. See below screenshot.
Kristine
Since the transactions are posted, you cannot change main currency or reporting currency.
On General ledger, Click Periodic → Currency conversion → Ledger reporting currency conversion. This feature allow you to change the reporting currency but you need to change it thoroughly specially from reporting perspective. I believe system will convert the currency and adjust the value as per exchange rate for the historical transactions and new transaction will have take new reporting currency for transactions.
Pranav…
Hi Pranav,
Thank you so much for the reply. Do I still need to revert forex revaluation on customer and vendor then close previous fiscal years for changing the reporting currency?
Kristine
Hi Kristine,
I don’t think that will be required, system asks for conversion rate for the new currency, i think system will convert the transactions at ledger level. Please test this in any test environment before doing this in PROD.
Pranav…
Hi Pranav,
Okay, thanks for the answer! Will test it.
Kristine
hi,
In CustAccountStatement Report i want to show Reporting currency as INR …but if i have transaction in INR its working fine but when i have transaction in USD its showing result in USD only…it means report is showing value in transaction currency but i want it in INR…can you please help for this scenario
Manali
In customer account statement it will show in transaction currency only. With small customization you show in your specific currency (if the transaction currency & reporting currency have a relation)
Thanks for reply…
Can you please suggest me how to go through customisation like transaction in USD and INR so how to show result in INR in report
First you need to analyze
  1. How report data is coming. After finding customize the classes and write your logic for currency conversion
    If USD & INR are related.
  2. If INR is the setup as accounting currency or reporting currency , then the transaction currency(USD /EUR…etc) & INR are related with a exchange rate factor for all the transactions.
    Note: It would take time & need to do yourself or hire a developer.
