Changing logic of an RDP class
Hi, Every One
Can we modify system posting logic? like PO Invoice Posting.
It obviously depends on what change you want to make.
Hi Martin
I add a custom design for PO confirmation report and use SSRS print management set my report design, i also add some custom field on po line.How to change system po comfirmation report DP class, that can i show the custom field on report? Directly change system po cofirmation class?
If you use application version 8.0, you can’t overlayer the class and modify it. You must use extensions.
In particular, look at the Chain of Command feature.
By the way, the thread title should describe the topic of the particular thread, which “System Logic Change” doesn’t do very well. Let me change it to something more specific.
