Hi, We registered some invoices in the Invoice pool (using Inv. Register). Unfortunately some of the invoices had wrong dimension specified against it [:(] Now I want to change dimension for those invoices. I am aware that I can use Function → Cancel in Inv. approval journal to cancel them and re-register it. But apart from the above - is there any other way to change dimension for invoices existing in the Invoice pool? Thanks, Harish Mohanbabu http://www.harishm.com/
Harish, I’ve got the same problem, but then with field PurchIdRange that I filled wrong in the invoice pool. Re-register is not a very ‘friendly’ solution, but as far as I know the only one[V]
