Changing check fonts
I managed to figure out where to change the fonts and when I run a test check all of the changes I made are there. However when the actual check is printed, I do not see the changes.
I did see a compile option, do changes in AOT need to be compiled? This is a bit confusing since the test check showed the changes without having to compile.
Thank You
