Changing an item number
I’m trying to change an item number NSSSFD381612 to SSFD381612 and am getting an error:
The Calculation Line Location Code=‘Hammond’, Item No.=‘SSFD381612’,Variant Code=’’,Line No.=‘1’,Source No.’’ already exists. Identification fields and values: Location Code=‘Hammond’, Item No.=‘NSSSFD381612’,Cariant Code=’’,Line No.=‘1’, Source No.=’’
No idea what this means or how to fix it, any suggestions?
Rachel
seems to be a problem with a customization in table Item. check trigger No.- OnValidate and OnModify.
in your case when changing an item no. an calculation line is created, but should be modified.
Welcome to DUG!!!
Before modifying the item kindly check any customization done for this as in standard Navision it always check that is there any entries are open in ILE and same way may be the customization done based on you requirement by partners/developers.
