Changing a dimension description
When a I try to change the dimension description, I receive an error, illegal brand id.
This dimension has been used in the system, can you still change the description or your are stuck with it.
Sounds to me like you have modified this, can you debug?
yes it was modified, I found how to fix it. Thanks
