Change the position of tools dynamically in the reports
Hello,
I’d like to know if it’s possible, to change dynamically the location of a textBox or an other tool in visual studio ? for the reports.
Thank you for your help.
One way is typically to create the same field in different positions and then dynamically decide which field to display.
No, not in this way, I don’t know the position which is calculated !
So if you don’t know the position of the fields on the report, then how would you then be able to develop the report?
Are you getting the field positions as coordinates or what?
I meant I do not know the position, in that position it is not fixed, in fact the position is calculated according to several parameteres.
I think if you want anyone to be able to help you, then you should add a few more details.
