Change status of Batch Job using X++
I have created a Batch Job using SysOperationFramework. I want to change the status of my Batch Job using X++ code.
When and why do you want to change the status? Normally it’s handled by the framework.
After execution of the batch the status will be ended now I want the status need to be changed to withhold. It is easy to change manually but i’m trying to change using X++.
Hope you got my Idea.
What business problem you’re trying to solve by this technical design?
Maybe we can find a better solution when we understand the actual problem.
yeah Thanks. Actually I am working on a project which Automate the batch processing activity using sysoperationframework
