On a customer environment I’ve got several issues caused by an active primary stocking flag on InventLocationId and WMSLocationId on the dimension groups.
During reserving in the shipments I get in troubles if this storage dimensions are on primary stocking but inventory on hand ist only available on an other invent location than registered (Note: My item is already physical reserved since item reception) on WMSOrderTrans.
So may be the better solution is to remove the primary stocking on InventLocationId and WMSLocationId. But that cannot be done if inventory transactions for any item within the same dimension group do exist. This kind of validation is very simple donen by ax and may be it is even not necessary to do that for the primary stocking field. Of course it has to be done ich users want to change e.g.: allow blank issue/receive flags.
Has anybody experience with similar cases?
