Change of Item Tax Group in Sales Line of an item.
I want to change an item Tax Group id of an particular item corresponding to all sales line in table.
Real Problem happened:
Global setup for that item, item tax group is assigned wrongly, so all sales line created for that item has the same itemtaxgroup id.
Am planning to run a job to update taxItemGroup id for all sales line to that item. Will it affect any tax calculation when invoice is created?
Please share your ideas.
Thanks & regards.
Ramya
What happens when you test it on one transaction before you write a job to update all?
Hi adam,
Am not aware what will be the next flow to be done.
please guide me.
Thanks & regards,
Ramya
Change the item tax group on the line, invoice it, see if it works for you.
thankx adam.
I have created new sales order and sales lines and changed the item tax group and i did posting ->Picking list, Packing Slip and Invoice
Status updated to invoiced.
I want to know is there any calculation based on item tax group when sales order status is in open order and invoiced.
Thanks & regards,
ramya
Only when you press totals, all other tax elements are performed at invoice, although you may want to check that statement with your localisation.
