Change OF AIF outbound file format as required
Dear All,
Can any one please suggest me how can i change my Outbound file format as required In AX2012 R3
Giri
I can’t, because I don’t know what you require.
Dear Martin ,
I have created outbound document services using AIF . I were generation the outbound file format as 20150303_013021_5701159_00001.xml . Now my requirement is to generate File format as Vendorname_Date(DDMMYYY) .XML
Giribabu
It sounds you just want a different file name, not the file format, right? In that case, modify the existing file system adapter class or create a custom one based on the default one.
Dear Martin,
Thanks for your reply
Yes as per your understanding i need the different file name .
Dear Martin,
Yes as per your understanding i need the different file name .How can i achieve this and which class need to modified
Giribabu.T
Unfortunately I don’t have any AX 2012 application around, but I know it’s done by AifFileSystemSendAdapter class. I would look into getNewOutFileName() method.
Dear Martin,
Dear Martin ,
I will check with the class which you have specified by you in the above reply and come back to you if needed
Giribabu.T
hi giri8572
did you come right with this? I am needing the same thing.
