In earlier version could you change menu colour to mark a company as TEST or DEMO. Also some customers with many companies require visual change to see with company they are working in. (Yes I know you could see it in main frame window bar.) In 4.0 is menu a part of C/SIDE environment, and I can’t finding any way to modify colour or something else in menu wit some code. Does any one have a solution to visual display that the users not are in the “sharp” company? Best Regards
Hi, I woulkd like to know if you have found a way to change the color of the menu in Navision 4.0. We have the same issue as you did and would like to be able to change the color of the menu.
Try this form: just change CU1 to run it when user logs in.
Attachment: Nav4.0CompanyInformation.fob ( 1890bytes )
quote:
Try this form: just change CU1 to run it when user logs in. Attachment: Nav4.0CompanyInformation.fob ( 1890bytes )
Originally posted by tb@softsys.at - 2005 Dec 06 : 07:50:31
Download isn’t working, Could you send this to me?
Or just post the relevant code please
My guess is that you can add a new function to codeunit 1 with ID=1 This function will be triggered when you press F12. You can put a message or a form in this function that displays the companyname.
OK alternative download: Just for you [:p] http://www.brodkorb.at/Nav4.0CompanyInformation.zip
