I have activated the change log functionality in Navision on Item Table(27) for all the fields and all functions (insert/modify/delete).
I have activated the change log and setup the item table there for all fields.
Then when i goto ITEM CARD FORM and do any transaction (insert/modify/delete) it is showing nothing in the change log entries. Even i use to change the same on the table it self but nothing.
I am login in with SUPER user.
Do i have to run some batch job to get it filled in change log entries. or there is some other setup to be done.
Please guys need your help in this regards.
Thanks.
