Hi all, a problem concerning the Change Log Management. Is it possible to log the modifications made using a codeunit? Apparently the Change Log Management works only with interactive modifications. thanks you all, Marco
I’m looking for the same answer. Can anyone help?
I join to the question [:)] Please help!
It is possible to call the Change Log Management codeunit directly, but you would have to add the call to every codeunit you want to log. ie… Table.INSERT; ChangeLogMgmt.LogModification(RecRef,xRecRef)
Obviously, You will have to set the RecRef, xRecRef variables to the the correct values [:)].
