how to change date type to be code type
so I want to generate document number like this
Today = 06/16/10
so i want the Document No. → DOC 06/16/10
what should i do to be done like this?
thanks
Today = 06/16/10
thanks
cant you change the date type in the table against the fields?
what do you mean by that you want your Doc no to be like DOC 06/16/10?
06/16/10 tis a date data type right!
sorry, i really cant understand your query.
I want to import data from csv using dataport
so I want to generate document no automatically…
document no should be → DOC 06/16/10
DOC is default
06/16/10 is date of today
in the csv file, I don’t input any document no
WWhat about:
Text := STRSUBSTNO(’%1 %2’,‘DOC’,TODAY);
Where TExt is a variable of data type Text.
The FORMAT command will change date to text.
gsPostingDate := FORMAT(“Posting Date”);
almost correct
but my document no field is code
not text
how to change to be code type
You must be joking… NAV will convert Text to Code… Just use
“Document No.” := STRSUBSTNO(’%1 %2’,‘DOC’,TODAY);
Okay… my mistake
the code is okay
thanks everyone
