Hi, Does anyone know how to change the database that the Navision server is using? I tried new startup parameters, but can’t get it to work. I do not want to re-install the server. Thanks Trin
Hi Trin, long time no hear, hows it going? ANyway… open Services, find the Navision server. Stop the sevice. In the paramaters field type “Database=drive:\path\dbname.fdb” Hit start (NOT OK). When the service starts you should be OK. What you probably did was hit OK instead of start, its the most common mistake.
