Change code in an AOT map's method
If I change the code in AOT map object’s method, such as PriceDiscHeading.updateFinalDisc, do I’ve to do a full AOT compile to cover all objects or just compile the object I changed.
Thanks.
Just compiling the object would suffice, unless you have added new parameter to that method (that is not optional) or change return value.
