We have a requirement to replave the child item A with item B,wherever item A is defined in BOM Versions.
When we tried the same with “Change BOM Item” option in Inventory and Warehouse Management > Periodic > Change BOM Item,system replaced all BOM Versions lines available in the company with item B. Idealy it should replace only those BOM Lines where item A is defined.
It seems the filter “BOM Line” si not working properly & it’s a bug in AX 2012.
To do the same we have selected the below mentioned fields in ,
Parameters Section :
To Item Number : A
Update Lines : Overrite
BOM Lines Section:
- Item Number : B
Then pressed “OK” & checked all BOM Versions & got that all BOM Versions lines were replaced with item B,instead of replacing only those BOM versions where item : A was defined as line item… In this scenario only two BOM Versions should be affected where item :A was available.
Expecting help from all of you guys.
Thanks in advance.
Nitin Patel
