Change / Arrange field position on Item Page?
Hello Community,
I would like to know how i can change the position of a standard fiel on a standard page (e.g.“No.” on the page item) by code.
Thank you in advance.
You’d need to create a pageextension object
You need to use Page Customization Object. Please refer here
https://docs.microsoft.com/en-us/dynamics365/business-central/dev-itpro/developer/devenv-page-customization-object
You need to do a bit research on Business Central, every 2 minutes job which we used to on NAV is not that quick in Business Central [emoticon:c4563cd7d5574777a71c318021cbbcc8]
Every little standard modification needs to go with Extensions.
