Hi guru’s
Iam New to D365.
Is it possible to write coc for making some form fileds read only on certain conditions
Regards
Sure, making fields read-only from code is possible. Code called through CoC is no exception.
Get a reference to a data source field and call its allowEdit() method. Set it to false
if the field should be readonly and don’t forget to enable it again when needed.
For example:
boolean editable = ...;
myTable_ds.object(MyTable, MyField)).allowEdit(editable);
thank you sir
but can i do it at formfield level ?
for ex i want to make sales price editable only for return order
but there are no methods availbale for salesprice field
regards
Which form and form control do you have in mind?
