In AX 2012, the CCADO classes have been entirely removed, and I’m just looking for someone to point me in the right direction in terms of what they’re been replaced with. I am moving a mod up from an AX 4.0 environment to an AX 2012 environment, and it uses CCADO objects extensively to call out to a staging database. What is the proper solution to this in AX 2012?
You can use the .Net classes from System.Data.SqlClient.*
http://msdn.microsoft.com/en-us/library/system.data.sqlclient.sqldatareader.aspx#Y3191
