static void ADOTestJob(Args _args)
#CCADO
CCADOConnection ccConnection;
CCADOCommand ccCommand;
CCADORecordSet ccRecordset;
CCADOFields ccFields;
str st;
str data1;
int data2;
ccConnection = new CCADOConnection();
// Setting the connection string
ccConnection.connectionString(StrFmt(‘Provider=SQLOLEDB.1;Persist Security Info=False;User ID=%3;Password=%4;Initial Catalog=%2;Data Source=%1’
, ‘UATServer’ // Server’s IP or name
, ‘FWSalesHistoryDB’ // Database or catalog
, ‘reddy’ // Username
, ‘Pass@word1’ // Password
// Open the connection
ccConnection.open();
// Preparing the query
st = “SELECT * FROM FWDailyHistorySales”;
// Recordset object creation
ccRecordset = new CCADORecordSet();
// Executing the query
ccRecordset.open( st, ccConnection);
// Reading data
while (!ccRecordset.EOF())
ccFields = ccRecordset.fields();
ltDailySalesDataHist.Transdate = ccFields.itemName(“TransDate”).value(); //resultSet.getDate(1);
ltDailySalesDataHist.DayOfWeek = ccFields.itemName(“Day”).value();
ltDailySalesDataHist.LocationID = ccFields.itemName(“Store”).value();
ltDailySalesDataHist.SalesAmount = ccFields.itemName(“SalesAmount”).value();
ltDailySalesDataHist.SalesCount = ccFields.itemName(“InvCount”).value();
ltDailySalesDataHist.Customer = (select DefaultCustAccount from RetailChannelTable
Where RetailChannelTable.inventLocation == ltDailySalesDataHist.LocationID).DefaultCustAccount;
ltDailySalesDataHist.insert();
// We can access fields either by name or by Index
data1 = ccFields.itemName(“FIELD1”).value();
data2 = ccFields.itemIdx(1).value();
info(strfmt(“Data %1, %2”, data1, data2));
// Read next record
ccRecordset.moveNext();
// Closing the connection
ccRecordset.close();
ccConnection.close();
error:
Variable CCADOConnection has not been declared.
