caption change automatic
can this happen in nav5
dimcol1 = dimension column1 = departments, loccol =location column
in item journals…when i select positive adjustment… caption of dimcol1 = “issued by”, loccol = “input to”,
if negative adjustment…caption of dimcol1 = “issued to”, loccol = “take out from”
is this possible pls any advice…
many thanks
There is a property called CaptionClass for these kind of tings.
But what is the caption supposed to be if you have lines with multiple Entry Types in the same Journal???
