Hello,
AX 4.0
I have single workcentergroup (A) with attached 3 workcenters (B,C,D) in this group. I have defined 3 qty of workcenter in route to allocate the multiple workcenters when we run the master plan. Now when I check the results in plan orders it shows like this
Operation |
Priority |
Workcenter |
Start time |
End time |
10 |
Primary |
B |
10:00 |
20:00 |
10 |
Primary |
B |
10:00 |
20:00 |
10 |
Primary |
B |
10:00 |
20:00 |
Logically instated B Workcenter on the 2nd and 3rd line, it should have to show C and D Workcenter.
I am using Finite capacity.
Can anyone please tell that what setup I am missing to get Workcenter C and D in 2nd and 3rd line.
Can you post a screen shot of your route, and where you have selected finite scheduling? Work centre, master plan, etc. Version 4 is now 10+ years old so seeing it may assist.
Thanks for reply Adam
Yes I have activated finite Capacity on Work center, Master plan and production.
Please check the attached screenshot of the route and generated plan orders.
- Route
- Plan orders
You need to strip it back - take the load restriction out at 33%, not sure why you have that when it is group scheduling at that level. I cannot see the WCG configuration or the WC configuration, but assuming you have this working in another setup for 4.0 I suggest you review the differences. No access to an AX4.0 system so difficult to advise.
I have check this by updating load100%. but this time I am getting this error " "The referenced work center cannot comply with the work center quantity requirement of the route.
I also have created WCG and WC manually to check the same issue with same setup and it’s working fine.
Now I have the same setup for the old and new WCG & WC but I still have the same problem for the old WCG & WC.
Old data was uploaded (Imported).
You will have to get a developer to debug it, or hope someone on here has access to AX4
Thanks Adam
ok. I will check with developer.
[mention:88448e7fc4a54a46abcd1c9cb090047b:e9ed411860ed4f2ba0265705b8793d05]
Did you find out the fix for your issue bcoz even I am facing similar issue.
Please share your thoughts. Thanks
