Hello,
I have been asked to create a matrix report with ‘Description’ & ‘Quantity’ fields. Those fields are existed & fetch data from two different tables named ‘Item Journal Line’ & ‘Item Ledger Entry’.
For that I have declared two record variables(RecIJL, RecILE) & ‘Description’ & ‘Quantity’ variable . I have declared only one DataItem i.e. Production Entry Header. Then I took all required fields along with ‘Description’ & ‘Quantity’ variable.
Now I want when a user selects a ‘Document No.’ the report will shows all Description values as column header caption along with quantity as their body. But my code doesn’t retrieve all the values except only the last one. I have written the following code:
Production Entry Header - OnAfterGetRecord()
RecIJL.RESET;
RecIJL.SETRANGE(RecIJL.“Document No.”,“Production Entry Header”.“Document No.”);
RecIJL.SETFILTER(RecIJL.“Item Type”, ‘%1’ ,RecIJL.“Item Type”::Scrap);
CLEAR(Description);
Quantity:=0;
IF RecIJL.FINDFIRST THEN BEGIN REPEAT
Description:=RecIJL.Description;
Quantity:=RecIJL.Quantity;
UNTIL RecIJL.NEXT=0;
END Else
RecILE.RESET;
RecILE.SETRANGE(RecILE.“Document No.”,“Production Entry Header”.“Document No.”);
RecILE.SETRANGE(RecILE.“Item Type”, RecILe.“Item Type”::Scrap);
IF RecILE.FINDFIRST THEN BEGIN REPEAT
Description:=RecILE.Description;
Quantity:=RecILE.Quantity;
END;
Can anyone help me?? Thanking You,
