Can't administrate privileges and webservices
HI there,
I’ve installed the Demo version of NAV 09 (6.0) since im working on a website integration for nav 09.
I m trying to verify data on my page against navision using webservices. Unfortunately i didnt even get to the point
that i m able to open a webservice.
I created a couple of webservices using the 810 Dialog to define a couple of pages, also i hit the ‘publish’ button.
I used the object type ‘Page’ and defined the names ‘CompanyInfo’ and ‘Liquidity’.
When i call up the overview page for the webservices I only get the response showing the SystemService
(Im using the following URL: http://servername:7047/DynamicsNAV/WS/Services). I m not getting any info about my other two webservices.
I suspect that i may not have the priviliges to actually do that since i get the message ‘You do not have permission to read the ‘Web Services’ Form. Contact your system administrator to have your permissions changed.’ when i try to open the object designer…
is there anyway to get this going in the demo environment?
thanks a bunch
