When I adjust cost ,It has error occur “Amount must be 0 in Item Jounal Line Jounal Template Name.”,Junal Batch Name =",Line No.= ‘0’. How can I do ? Thank You Suebsant Garudabandhu
Hi Buddy, I think u may need to give the version ur using… If ur using NA3.60 then this is solved in Hotfix 19… cheers… jhc
perhap you may use debugger and find out which line cause the error.
Thank you I’ll be try again
