Cannot set sizes of my SysLookupMultiSelectCtrl
as subject said, I am not able to find out where to set the sizes (height & width) for my SysLookupMultiSelectCtrl. I alredy set the Width & Height property under the StringEdit element that controls SysLookupMultiSelectCtrl to be respectively Column width & Column heigth, but still when the dropdown window shows, the info into fileds are not totally visible but they have being trunked and partially shown. How can I enlarge those fields in my SysLookupMultiSelectCtrl?Is there any Class that controls that too?
Thank you in advance, and I hope was clear explaining myself!
this may be help you
dynamicsuser.net/…/56085
Thank you! This worked perfectly! I added the size under the property DisplayLenght of my EDT.
