Cannot Send SMS via GSM modem using AX2009
Hi fren,
i’ve issue on sending SMS via GSM modem by AX code. i tried to run this on AX job but somehow, it doesnt send me SMS. However, if i’m using hyperterminal, it’s work. Plus, in hyperterminal i need to check “Force incoming data to 7-bit ASCII” at it’s properties, then can send SMS. if not, no working.
Can u guys help me on this? Thank you.
This is my code :
System.IO.Ports.SerialPort port;
str _charZ = num2char(hex2int(“Z”));
char Z = num2char(26);
try
port= new System.IO.Ports.SerialPort();
port.set_PortName(“COM4”);
port.set_BaudRate(115200);
port.set_Parity(System.IO.Ports.Parity::None);
port.set_DataBits(8);
port.set_StopBits(System.IO.Ports.StopBits::One);
port.set_Handshake(System.IO.Ports.Handshake::None);
port.set_DtrEnable(true);
port.set_RtsEnable(true);
port.set_NewLine(System.Environment::get_NewLine());
port.Open();
if(port.get_IsOpen())
port.WriteLine(“AT”);
port.WriteLine(“AT+CMGF=1”); //set message mode to TEXT
port.WriteLine(“AT+CMGS =\‘01334093214936’\”);
port.WriteLine(“TEST”); //type message text
port.WriteLine(Z); //corresponds to pushing Ctrl+Z
port.Close();
catch(Exception::CLRError)
throw Error(port.ToString()); pause;
