Cannot select Date from Date Field in Enterprise portal
I have form in enterprise portal display date field from the data source of form data set
the problem is that i can write date manual but can’t select the date from date picker
I made refresh for data set and caches and reset iis but problem not solved
Please any help will be appreciated.
Check the EDT you used for this. This might help.
