Cannot pass a parameter value to the destination class in EP
I'm using WebLink()-class and webaction-menu item to execute the destination
class. However I can't get the param value out of the args in the destination
side. I'm sure it's there but I just can't get it out.
Example:
I initialize the parameters for testing;
webLinkAddItem = new WebLink();
webLinkAddItem.addOrUpdateExtraParam('test', 'testing');
webLinkAddItem.parm("something");
webLinkAddItem.menufunction(new
WebActionMenuFunction(webactionitemstr(EPAddLine)));
Then in the destination class Main()-method:
str searchval = webSession().getParm('WP');
str val2 = webSession().getParm('test');
These both won't return anything. I'm sure it's there because the string in
websession shows them:
["__EVENTARGUMENT"->"EPAddLine?WP=something¤&test=testing&WTID=175&WREC=5639142111&WKEY=[65534:5639142111]....
I can get out WTID and WREC values though, I wonder why?
Please, could someone answer this.
Hello,
In the destination class, are you using args class to receive arguments?
Some additional things to check -
  1. Check whether you have correct security access in your code. For inspiration have a look at WebPortalExecutionEngine class → processWebMenuFunction
  2. If you haven’t already done so, try enabling it (http://msdn.microsoft.com/en-us/library/aa629010.aspx) and debug your code.
Hope this helps,
I certanly have debugged it. In ProcessWebMenuFunction(), args get initialized:
aa.parm(mf.parameters());
My guess is, it fails to add a parameter to weblink:
myWebLink.parm(“testing”);
This is one of the weirdiest things I have bumped with AX.
Hi again,
I have tried to use a global variable which I added to websession-class, so that I wouldn’t have to pass parameters with weblink. But it didn’t work either - in destination class, the websession’s value was different than in caller class. This is really mindblowing.
