When I go to Organization Administration\ Setup\ Addresses\ Address Setup \ Country/Region it will not let me delete a specific value from the grid (GBR)…I get the following infolog:
Country/region cannot be deleted while dependent Addresses exist. Delete dependent Addresses and try again.
Can anyone tell me what this means or better yet, how to find these ‘dependent addresses’?
It means that the Country/region is used on an address and if you delete that, it would would point to a non-existing Country/region. You can find the addresses by filtering by CountryRegionId in LogisticsPostalAddress table.
It’s a standard system check caused by a restricted delete action.
