GL>Setup>Ledger
Unable to open Ledger.
Cannot create a record in Ledger (Ledger). Ledger name: X, X.
The record already exists.
Why this happen?
GL>Setup>Ledger
Why this happen?
Please refer the following link, it might help you.
http://dynamicsuser.net/forums/p/36221/188310.aspx
If solved your problem, please verify me.
Happy Daxing…
“Basic ----- > Setup ----> Number Sequence ----> Number Sequences------> Number Sequence code----- select Number Sequence code (in my case its was Gene_5) then go to General tab… Under Number Allocation changed NEXT: number as 9953.”
I am using Dynamics AX 2012 R2.
Where is this “Basic”?
Problem solved…I dnnt know how it happend…? When I reopen the ledger…no more error message…Now can view the ledger
Getting the same error message - how do you know which Number Sequence Code to review?
Thank you.
