Cannot create a record in (CustTable).
hi all
while upload the customer data,
am getting errror like
Cannot create a record in (CustTable). Customer account: [Customer No. and Name]. The record already exists".
pls anyon help me
thanx in advance…
It seems to be a numberSequence problem, you should check your AX params (path : your_company/Basis/setup/NumberSequences
Thomas
Assuming you are importing the customer number it is telling you that there is a duplicate - you cannot have 2 customer records with teh same customer number. Check your data.
If you have access to customersource microsoft tells you how to import customers/vendors:
https://mbs2.microsoft.com/Knowledgebase/kbdisplay.aspx?wtntzsmnwukntmmyszrrnottukoostllwskmmqvylslnwrus
There is a better chance this is related to PartyId being blank for all of your customers, but it could also be related to your AccountNum.
