Dear ., I am having problems compiling the Attachment table. For some reason it cannot find a type library for a local variable CDOHandler in the LinkToMessage() function. A similar problem occurs in the E-mail Logging code unit. Can anyone confirm, and maybe tell me how to solve this problem? P.S. I’m using a 3.60 database
Did you install the “collabortation data objects” in the Outlook Setup ? Check this out.
This is because “NSAppHandler.dll” is not registered. This contains CDOHandler and OutlookHandler - both of which are required for this table.
