I want to access the excel files from Navision CA/L Code.I ave to specify the excel path to access the file.I am getting the server path and i am then concatenating the server path with the file path.
For example if Server name is Server1 and file is in D:\Sample.xls Then i have given the path as
Path := ‘//Server1/D$/Sample.xls’
But it is not working
I can access the file from Local Machine but not from server.
a) Create a folder on the D: drive of server1, for example Samples
b) Share the folder, for example as Samples, and set permissions
c) Map the share in the local computer, for example as Y:
