Can you schedule reports. Wanting to setup customer statements to print after hours using EasyPDF.
Yes you can do that using NAS.
This is done using the Job Queue (which as Saurav writes runs using the NAS).
You didn’t mention which version of Navision you are using. If after 2013, then you can schedule the report to be run directly from the report. Before then you need to add it manually to the job queue.
You report of course also need to be able to use EasyPDF (incl. assigning file names etc.) without any user interaction for it to work. EasyPDF is not standard functionality.
