I have created one HTML Page for explaining some Document information. and also create one Page using AL [ie. Posting setup]. in that, I want to create a button to display HTML Page.
can we open the HTML page?
Thanks in Advanced.
Thanks in Advanced.
use a control addin!
from JS you could import some HTML like so:
Control Addin Object - Business Central | Microsoft Docs
Thanks for your reply. I have used control Add. But I am unable to display Image in Control Add-in Page. But it displays HTML Tag. ie
I have done Control Add-in as follows.
Demo Page to display Control Add-in [DempPage.al]
Create user Control controladdin page AL [UserControal.al]
Then last two JS Script startup and script [startup.js, script.js]
Could you help that below code where I am wrong due to the image not display.
page 50147 "Demo Page"
Caption = 'Demo Page';
layout
area(Content)
usercontrol(html; HTML)
ApplicationArea = all;
trigger ControlReady()
begin
CurrPage.html.Render('<html><body><h1>The img element</h1><img src="../img/img_girl.jpg" alt="Girl in a jacket" width="100" height="100"></body></html>');
end;
/*User Contraol.al*/
controladdin HTML
/* RequestedHeight = 300;
MinimumHeight = 300;
MaximumHeight = 300;
RequestedWidth = 700;
MinimumWidth = 700;
MaximumWidth = 700; */
VerticalStretch = true;
VerticalShrink = true;
HorizontalStretch = true;
HorizontalShrink = true;
Scripts = 'script.js';
StartupScript = 'startup.js';
event ControlReady();
procedure Render(HTML: Text);
/* script.js */
function Render(html)
HTMLContainer.insertAdjacentHTML('beforeend',html);
/* startup.js */
HTMLContainer = document.getElementById("controlAddIn");
Microsoft.Dynamics.NAV.InvokeExtensibilityMethod("ControlReady",[]);
in order to get the images you need to reference that in the properties of the control addin object (Images Property - Business Central | Microsoft Docs)
and then you must get them by using this GetImageResource Method - Business Central | Microsoft Docs
