Hi All ,
I have done 4 SSRS report in AX 2012 CU7 R2 but my destination server have the configuration AX 2012 R2 Base .
when i move the xpo then it threw some version conflict error .
Is there any way to move the design part to AX 2012 Cu7 R2 → Ax 2012 R2 ?
Sumit
Some error requires some solution. Please be more specific.
Hi Martin,
Thanks for your reply
Below the the error:
\C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll 0 0 178 AX1004: Reference System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 was not a valid model assembly. 127 System.Core.dll 0 0 2 AX1004: Reference System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 was not a valid model assembly. 2 0 0 2 8/7/2014 08:54:35 am 51875 0 5637144576 \C:\Windows\Microsoft.NET\Framework\v4.0.30319\Microsoft.Common.targets 5 983 178 MSB3644: The reference assemblies for framework “.NETFramework,Version=v4.0” were not found. To resolve this, install the SDK or Targeting Pack for this framework version or retarget your application to a version of the framework for which you have t 127 Microsoft.Common.targets 1 1 1 MSB3644: The reference assemblies for framework “.NETFramework,Version=v4.0” were not found. To resolve this, install the SDK or Targeting Pack for this framework version or retarget your application to a version of the framework for which you have the SDK or 1 0 0 2 8/7/2014 08:53:48 am 51828 0 5637144576
Kindly mention, is there any way to import or i have to redesign the report .
Sumit
When exactly do you get this error? It seems to be referring to a model assembly, nevertheless you said you’re moving an .xpo, so it’s not clear to me what’s going on.
Hi Martin ,
thanks Man for reply !!!
After importing my development project XPO , I compile the shared project then got as mentioned error .
Sumit
Please compile objects one by one and tell us which one is causing the problem.
Hi Martin ,
Thanks Man again .
I complied One by one there are no error for other object except Visual studio object (Dynamics Ax Model project).
I mean when compiled Visual studio Object , It’s throwing below error
Sumit
It’s not clear to me why there should be a problem about System.Core. Don’t you get another error if you open the project in Visual Studio and compile it there?
