can we create an dynamic objects of a class.
say I have a class AxLedgerJournalTrans can we create 10 dynamic objects for the same.
any tutorial will be appreciated.
Sure, it’s possible and if you want a classic array, it work exactly as described in the documentation (MSDN: Arrays). Here is an additional example with objects:
Tax taxArray [10];
taxArray[1] = new Tax();
taxArray[2] = new Tax();
You could also use the Array class. Nevertheless neither option is too common in AX; usually you’ll see other collection classes such as List and Set. Again, refer to the documentation for details (MSDN: Collection Classes in Microsoft Dynamics AX).
You see that the documentation contains a lot of useful information. The sooner you start using it, the better for you.
Hi Martin when i put the same line
tax taxarray[50];
it throws error “illegal base type in array”
Did I forgot to compile the job? I must have done something silly as I’m trying to answer forum questions while working at the same some time…
All right, let’s use the Array class instead:
Array taxArray = new Array(10);
taxArray.value(1, new Tax());
taxArray.value(2, new Tax());
Nevertheless as I already said, other collection classes are more common. I almost never use arrays in AX.
I looked into documentation more closely and found that “The array syntax supports only primitive data types, such as int and str. The syntax does not support classes or tables.”
