Hello all,
I am new to NAV, and I am using NAV 5.0.
I am wondering if I can set two different locations for the Components at Location field in the Manufacturing Setup, under Planning tab.
We pull inventory from both of the locations for production. Currently it is only set to one location, so in the Item Card, the quantity on hand is only showing availablity from one location, and we have to manually check for the other location to see supply availability.
Is there a possibility to set up in NAV or does it require other coding to be done?
