can somebody teach me on how to solve my problem…for example 1 user will be the only one to put a tick mark on the accept action message column and the other users will only be able to view the said column??? help pls
i would like to do this in nav 5
thanx allan
Von,
Where are you experiencing this issue? What Version of Navision are you using? If you are using NAV2009 or 2009-SP1 are you using the Role Tailored Client? I think that information will help others in helping you.
Thanx,
Alan
How have you tried to solve the problem so far? What ideas have you had? This will prove to be a much better learning experience than someone just telling you the answer.
Von :
This should get you started :
1/ Create a field on table 91 - User Setup called. ie : “View Unit Cost” → Boolean
2/ add the business logic around the field created in step 1
