I am getting below error in ax 2012 r3 cu9. It suddenly occurred in ax.
"Cannot edit a record in LastValue (SysLastValue). UserID:., Usersetup.The SQL database has issued an error"(error coming while I starting ax also when opening sysusersetup form form File->Tools->options)
I have already tried below process to resolve the issue.
Full Compile
Full CIL
Database Synchronization(getting 2 or 3 error but it doesn’t seems to be related with above issue)
cleared cache
deleted AUC and KTI files
Restarted AOS service
AX Version: AX 2012 R3 CU9
I also checked event viewer it will indicating error 117
Any help would be appreciated.
Regards
Akshay
