Can not see Amyuni PDF Converter related dll file in Navision
Dear all experts
I’m new to use .ocx, .dll in navision.
Please see my problem here,
I need to send Statement of Accounts report to customers by e-mail in a PDF format.
But, my client’s OS (windows 2008 server) is not supporting PDF Creator, So, I found Amyuni to convert to PDF in the forum.
I installed Amyuni ( it’s free trial now), I can’t use it and I didn’t see any .dll files related to it on Navision Custom controls
I gone through the forums but didn’t find related solution
Hope some one can give me a suitable solution
Thanks in advance
Chowdary
I’m using PDF Creator with 2008 (32/64bit) and 2008R2 without any problems.
But did you define your variable as type OCX or Automation?
Automation servers are not shown in the custom controls.
If you do not find the controls in either OCX or Automation sub type you will need to check if the DLL/OCX is registered properly.
When running Win7 you will need to execute the setup with the “Run as Administrator” option even though you are an admin.
In worst case you could run the CMD command (again with “Run as Administrator”) navigate to the folder where the ocx/dll is located and register it manually with the “regsvr32” command.
