can i block the dimension based on the Module
Dear All,
I created two dimensions Monthly, Yearly through wizard.Now my requirement is Monthly dimension Should not apper in the Ap module . is it Possible To do?.then Plz tell me How.
You need to look at the dimension hierarchies and set it by posting, however I am not sure if this restricts the lookup, but instead prevents the posting.
