can anybody help to solve "Decimal rounding of the physical remaining quantity in the unit dwt is incorrect. "
While Posting Packing Slip I received below error , Can any body help me to resolve.
“Decimal rounding of the physical remaining quantity in the unit dwt is incorrect.”
Thanks in advance.
Ramesh
Hi Ramesh,
Please check for the Unit Decimals mentioned on the Unit dwt because the remaining quantity arrived on posting a packingslip should be equal to the round off applied on the units used for the particular line item.
Go to basic and just go to the units and test the units round is appearing correctly or not. Then you could adjust accordingly.
Regards
Raj.
HI Ramesh,
Please check for the unit decimals mentioned on the unit "dwt " Actually the remaining quantity should be equal to the decimal round off applied on the unit you have mentioned on the item in purchase line.
Go the the Basic and units and check for the conversion and round off , this should sove your problem.
Regards
Raj
Thanks Raj.
i will try it .
