Calling a external web site with in Dynamics Ax
I have built a new web site in ASP.net and is hosted in IIS as a web Site. Is there a way i can call this web site with in Dynamics Ax. What i mean is a Menu item which loads the default.aspx from the external site and continue traversing along the pages of the external site. Is this possible ?/
Thanks in advance,
Shankar
No need to create a menu item, if you want to open the URL in browser (Outside Ax). You can use following command:
WinApi::shellExecute(“www.google.com.au”);
But, if you want to open the same URL inside Ax, than you need to create a form with ActiveX control which acts like a browser, than create a menuitem which calls this form
Vijay Kishore
you can also try the following code:
infolog.urlLookup(‘http://page_you_want.com’);
hope it helps
regards,
Thomas
