Caller of Lookup form
hello ,
I am looking for how to retreive the caller of my lookup form when this form is called from a lookup method (ax 2012)
thks :wink:
use args.caller();
I did it but it returns null as value of the caller ,
this is init method of my lookup Form
void init
caller = element.args().caller();
if(TradeFormHelper::isCalledFromForm(element.args(), formStr(MyForm)) )
//MyForm is the form that call the lookup form
if (formHasMethod(caller,identifierStr(parmRunBase)))
Myclass= caller.parmRunBase();
// myclass manages MyForm
switch Myclass.parmBuffer().TableId)
and this is my lookup method in MyForm:
public void lookup()
Args args = new Args();
FormRun formRun;
args.name(formStr(MyFormLookup));
formRun= new ClassFactory::formRunClassOnClient(args);
formRun.run();
this.performFormLookup(formRun);
thks
Just try this:
if (element.args() && element.args().caller())
// Make sure this was via a form.
if(SysDictClass::is(element.args().caller(), classnum(FormRun)))
// Cast the caller and make sure it is the right form.
callerForm = element.args().caller();
if (callerForm.name() == formstr(Form1))
allOpenPostedField.selection(Upgrade::All);
thks :wink:
